EDM316 Compact Sinker Electrical Discharge Machining Center
Compact Sinker EDM for High-Precision Machining
The EXERON EDM316 is a compact sinker EDM designed for ultra-precise machining of complex geometries, fine details, and hard materials. Its heavy-duty cast construction, linear glass scales, and advanced dielectric system deliver exceptional accuracy and surface finish, even on intricate mold components and hardened workpieces. With user-friendly controls and thermal stability features, the EDM316 helps reduce setups and ensure consistent results.
Built for mold, die, aerospace, and medical part production, this machine combines precision, reliability, and space-saving design to meet the demands of today’s shops.
Country of Origin: Germany
BUILT FOR PRODUCTION
The EDM316 offers high-precision sinker EDM capabilities in a compact, shop-friendly footprint. Its rigid structure, glass scales, and advanced dielectric system ensure stable, accurate machining of complex parts and fine details. Ideal for mold, die, and aerospace work, it provides consistent results on hardened materials. With reliable performance and simplified operation, the EDM316 helps reduce setups and boost productivity for precision part production.
Travel (X/Y/Z)
59” x 46.45” x 31.5” (1500mm x 1180mm x 800mm)
Table Size
68.9” x 53.15” x 29.53” (1750mm x 1350mm x 750mm)
Max Workpiece Weight
17,637 lbs (8,000 kg)
Control System
EXERON MF30
Standout Features
Rigid casting, glass scales, compact footprint
Why Choose EXERON, a YCM Alliance Brand?
Built for shops that refuse to compromise on precision, speed, or support.
