Shipping costs calculated after purchase and will be coordinated with an AMROK Guide.
AMROK Double Angle Tombstone
AMROK® tombstones and grid plates are designed to hold the industry's highest tolerances for flatness, parallelism, perpendicularity, surface finish, and hole location. All tombstones and grid plates are built, tested for precision, then inspected using Advanced Machine & Engineering's in-house Coordinate Measuring Machine (CMM). Quality workholding for your toughest jobs!
#AMRD22forHC400II
Product Specifications
- Width: 12 in +/-.002
- Thickness: 4 in +/-.002
- Height: 22 in
- Base: 400 mm
- Mounting holes for DN Solutions HC 400 II
#AMRD26forNHP4000
- Width: 16 in +/-.002
- Height: 26 in
- Base: 400 mm
- Mounting holes for DN Solutions NHP 4000*
- Quick Response Tombstone: Yes
*Specify a tap pallet or t-slot pallet for the machine table.
#AMRD26forNHP5000
- Width: 20 in +/-.002
- Height: 26 in
- Base: 500 mm
- Mounting holes for DN Solutions NHP 5000
#AMRD32forNHP5500
- Thickness: 8 in +/-.002
- Height: 32 in
- Base: 500 mm
- Mounting holes for DN Solutions NHP 5500
#AMRD32forNHM5000
- Height: 32 in
- Base: 500 mm
- Mounting holes for DN Solutions NHM 5000
#AMRD36forNHP6300
- Width: 25 in +/-.002
- Height: 36 in
- Base: 630 mm
- Mounting holes for DN Solutions NHP 6300
#AMRD36forNHM6300
- Height: 36 in
- Base: 630 mm
- Mounting holes for DN Solutions NHM 6300
#AMRD40forNHM8000
- Width: 32 in +/-.002
- Height: 40 in
- Base: 800 mm
- Mounting holes for DN Solutions NHM 8000
#AMRD40forNHP8000
- Height: 40 in
- Base: 800 mm
- Mounting holes for DN Solutions NHP 8000
#AMRD50forNM1250
- Width: 40 in +/-.002
- Height: 50 in
- Base: 1000 mm
- Mounting holes for DN Solutions NM 1250
Product Benefits
- Edge locating (+/- .002 from milled edge to centerline)
- Includes lift holes for maneuverability
- Industry standard 2" grid pattern with alphanumeric engraving for flexibility in fixturing setups
- 1⁄2"-13 grid system offering hardened, threaded inserts and precision bushings
- Hardened, threaded inserts allow for clamping in every hole
- Quick and easy replicability
- Hardened, precision bushings are accurately located to ensure easy locating
- High wear resistance
- Hole plugs included to prevent chip build-up in vacant holes
- Cast Iron, Class # 35
Which Tombstone is Right for Your CNC Machine?
Cube
- Grid holes, bushings, and inserts are available for both 1/2" and 5/8" systems
- Hardened, threaded inserts allow for clamping in every hole while offering quick and easy replacability
- Hardened, precision bushings are accurately located to ensure easy locating coupled with high wear resistance
Double Angle
Cross Column
Quality is Built on a Precision Foundation
Why Choose AMROK?
American-Made Quality
Every tombstone is built in the USA to some of the industry’s tightest tolerances.
Alphanumeric Grid for Faster Loading
AME’s precision 2″ grid makes setups repeatable and efficient.
Hole Plugs Preinstalled
Pre-fitted plugs prevent chip build-up and simplify cleaning.
Advanced Material Options
Cast iron, epoxy mineral, and aluminum choices tailored to your application.
CMM-Verified Accuracy
Each fixture is inspected on state-of-the-art CMMs in a temperature-controlled environment for guaranteed precision.
