AL40G Die-Sinker EDM
Next-Generation Die-Sinker EDM for Precision Molds and Components
The Sodick AL40G combines advanced digital spark control, rigid linear motor drives, and thermal-stable construction for high-speed, high-accuracy EDM performance. Built for toolrooms and production environments, it achieves superior surface finishes and tight corner accuracy in steel, carbide, and exotic alloys.
Country of Origin: Japan
Precision EDM. Zero Compromise.
The AL40G integrates Sodick’s linear motor technology with a high-speed discharge circuit and adaptive Smart Pulse control. Each burn is monitored and adjusted in real time for optimal energy use and consistent finish quality, even on deep ribs or fine textures. The result: faster cycles, reduced electrode wear, and flawless dimensional accuracy.
X / Y / Z Travel
15.7 × 11.8 × 13.8 in (400 × 300 × 350 mm)
Work Tank Size
31.5 × 22.8 × 11.8 in (800 × 580 × 300 mm)
Max Workpiece Size
31.5 × 22.8 × 8.7 in (800 × 580 × 220 mm)
Max Workpiece Weight
1,100 lb (500 kg)
Electrode Weight
55 lb (25 kg)
Why Choose Sodick?
Pushing the Boundaries of Wire EDM.
