SYIL X5 Vertical Mill
Prices Starting at:
Space- and Money-Saving CNC Machine
- Axis travels of 11.8″ × 10.2″ × 11.8″ (300mm × 260mm × 300mm)
- 16-pocket servo automatic tool changer
- 20,000RPM BT30 direct-coupled spindle
- High-quality Epoxy Granite frame by SCHNEEBERGER (Swiss)
- High-precision ballscrew and linear guide by THK (Japan)
- SIEMENS SINUMERIK 828D 10" screen CNC Controller with 3-axis Servo Motors
- 3.3ft (1 meter) width for narrow spaces
- NC rotary table servo type
- 4th axis 125mm size kits including servo motors and driver
- Taiwan Made and Gear type
- Tail Stock for 125mm NC rotary table
- Face Plate Tailstock for 125mm NC rotary table
- Probe System: Wireless type
- Tool Setter Kits: Cable type TTC200
SYIL X5
A versatile CNC machine, perfect for hobbyists and professionals. Compact design, high precision, and affordable pricing.
22″ × 10.2" (560 × 260mm)
3 x 14" × 3.15" (80mm)
330lb (150kg)
79.5" × 39.4" × 92.9" (2020 × 1000 × 2360mm)
11.8″ (300mm)
10.2" (260mm)
11.8" (300mm)
5.9"-17.7" (150-450mm)
13" (330mm)
BT30
20,000 rpm
Direct
393.7 ipm (10 m/min)
1,181.1 ipm (30 m/min)
SCHNEEBERGER
Mineral cast machine frame
THK
4th Axis
Add a 4th axis to your 3-axis machining center
High-speed Servo Tool Changer
16 positions BT30
Robert S.
Why Choose the SYIL X5?
There are several advantages to using the SYIL X5 Vertical Mill for your machining needs.
The SYIL X5 Vertical Mill is smaller in size compared to its larger counterparts, making the machine ideal for limited space environments such as workshops or home garages. Its compact design allows for easy transportation and storage.
More affordable than larger CNC machines, the SYIL X5 offers a cost-effective solution for hobbyists, small businesses, or individuals who are just starting with CNC machining.
Despite their smaller size, the SYIL X5 can perform a wide range of machining operations. The machine is capable of milling, drilling, cutting, and engraving materials like wood, plastic, and various metals. This versatility makes it suitable for a variety of applications.
The SYIL X5 Vertical Mill is designed with user-friendliness in mind. It comes with intuitive control panels and software interfaces, making it easy to operate, even for beginners. Additionally, the machine has features like automatic tool changers and preset cutting paths, further simplifying the machining process.
Built with precision in mind, the SYIL X5 utilizes advanced technology and high-quality components to ensure accurate and precise machining results. This level of precision is crucial for creating intricate designs or working on small-scale projects.
With automated features and efficient machining capabilities, the SYIL X5 can save you a significant amount of time compared to traditional manual methods.
Additional Features
Wheel Type
16 Positions
2.5" (63mm)
7.9" (200mm)
6.6lb (3kg)
1s
4.8 kW
1/2.2/3.5 kW
AC380V/3-Phase
12 kVA
4806lb (2180kg)
