A Brand A-CSF 1/2-13 H5 3 Flute 1.5P Carbide Spiral Flute Tap
| Thread Size | 1/2-13 |
| Thread Type | UNC |
| Thread Pitch | 13 TPI |
| Class of Fit | 3B, 2B |
| Thread Limit | H5 |
| Chamfer Length | 0.115 in (2.931 mm) |
| Major Diameter | 0.500 in (12.700 mm) |
| Thread Length | 0.921 in (23.393 mm) |
| Tap Drill Size Range | 0.417 in (10.592 mm) - 0.434 in (11.024 mm) |
| Overall Length | 4.330 in (109.982 mm) |
| Shank Diameter | 0.367 in (9.322 mm) |
| Square Width | 0.275 in (6.985 mm) |
| Substrate | Carbide |
| Coolant Thru | Yes |
| Number of Flutes | 3 |
| Cutting Direction | RH |
| Helix Angle | 15 Degrees |
| Helix Direction | RH |
| Interrupted Thread | No |
| List Number | 16605 |
| Country of Origin | JPN |
| Net Product Weight | 0.21 lb |
Sale price$528.26
| Cast Iron | Best |
| Aluminum Casting | Best |
| Thread Type | UNC |
| Thread Limit | H5 |
