A Brand A-CSF M12 x 1.75 D6 3 Flute 1.5P Carbide Spiral Flute Tap
| Thread Size | M12 x 1.75 |
| Thread Type | M |
| Thread Pitch | 1.75 mm |
| Class of Fit | 4H, 6H |
| Thread Limit | D6 |
| Chamfer Length | 0.103 in (2.625 mm) |
| Major Diameter | 0.472 in (12.000 mm) |
| Thread Length | 0.827 in (21.000 mm) |
| Tap Drill Size Range | 0.398 in (10.106 mm) - 0.411 in (10.441 mm) |
| Overall Length | 4.331 in (110.000 mm) |
| Shank Diameter | 0.367 in (9.322 mm) |
| Square Width | 0.275 in (6.985 mm) |
| Substrate | Carbide |
| Coolant Thru | Yes |
| Number of Flutes | 3 |
| Cutting Direction | RH |
| Helix Angle | 15 Degrees |
| Helix Direction | RH |
| Interrupted Thread | No |
| List Number | 16600 |
| Country of Origin | JPN |
| Net Product Weight | 0.205 lb |
Sale price$505.81
| Cast Iron | Best |
| Aluminum Casting | Best |
| Thread Type | M |
| Thread Limit | D6 |
