A Brand A-CSF M10 x 1.25 D5 3 Flute 1.5P Carbide Spiral Flute Tap
| Thread Size | M10 x 1.25 |
| Thread Type | MF |
| Thread Pitch | 1.25 mm |
| Class of Fit | 4H, 6H |
| Thread Limit | D5 |
| Chamfer Length | 0.074 in (1.875 mm) |
| Major Diameter | 0.394 in (10.000 mm) |
| Thread Length | 0.709 in (18.000 mm) |
| Tap Drill Size Range | 0.340 in (8.647 mm) - 0.351 in (8.912 mm) |
| Neck Length | 1.535 in (39.000 mm) |
| Overall Length | 3.937 in (100.000 mm) |
| Shank Diameter | 0.381 in (9.677 mm) |
| Square Width | 0.286 in (7.264 mm) |
| Substrate | Carbide |
| Coolant Thru | Yes |
| Number of Flutes | 3 |
| Cutting Direction | RH |
| Helix Angle | 15 Degrees |
| Helix Direction | RH |
| Interrupted Thread | No |
| List Number | 16600 |
| Country of Origin | JPN |
| Net Product Weight | 0.175 lb |
Sale price$351.72
| Cast Iron | Best |
| Aluminum Casting | Best |
| Thread Type | MF |
| Thread Limit | D5 |
