A Brand A-CSF M6 x 1.0 D5 3 Flute 2.5P Carbide Spiral Flute Tap
| Thread Size | M6 x 1.0 |
| Thread Type | M |
| Thread Pitch | 1 mm |
| Class of Fit | 4H, 6H |
| Thread Limit | D5 |
| Chamfer Type | Modified Bottom (2.5P) |
| Chamfer Length | 0.098 in (2.500 mm) |
| Major Diameter | 0.236 in (6.000 mm) |
| Thread Length | 0.472 in (12.000 mm) |
| Tap Drill Size Range | 0.194 in (4.917 mm) - 0.203 in (5.153 mm) |
| Neck Length | 1.220 in (31.000 mm) |
| Overall Length | 3.150 in (80.000 mm) |
| Shank Diameter | 0.255 in (6.477 mm) |
| Square Length | 0.313 in (7.938 mm) |
| Square Width | 0.191 in (4.851 mm) |
| Substrate | Carbide |
| Coolant Thru | Yes |
| Number of Flutes | 3 |
| Cutting Direction | RH |
| Helix Angle | 15 Degrees |
| Helix Direction | RH |
| Interrupted Thread | No |
| List Number | 16600 |
| Country of Origin | JPN |
| Net Product Weight | 0.065 lb |
Sale price$212.00
| Cast Iron | Best |
| Aluminum Casting | Best |
| Thread Type | M |
| Thread Limit | D5 |
