FOX WS2 H13 HEPA Filter Module
Add H13 Final Filtration to Your FOX WS2
The optional H13 HEPA module adds a final filtration stage to FOX WS2 mist collectors for applications that generate fine particulate or dry smoke. Select the module that matches your WS2 model.
Download the Instruction Manual
Download the Filter Maintenance Guide
Save Money and Clear the Air
The Filter Kits bundle both the pre and main filter into one cost-saving package. Stock up on the filters you need to keep your air clean and budget balanced.
Oil-Emulsion Filters
HEPA 13
