EMCO ECOMILL 1200 3-Axis CNC Machining Center
Compact and Versatile 3-Axis Machining Center
The EMCO ECOMILL 1200 is a precision 3-axis CNC machining center designed for versatility and efficiency. Featuring a compact footprint and robust construction, it offers powerful performance for various milling applications. Its solid fixed table supports workpieces up to 1,500 kg, ensuring stability and accuracy.
This machining center is equipped with state-of-the-art control technology, available with Siemens 828D with ShopMill or Heidenhain TNC 620. The machine bed is made from optimized welded steel, and the cast-iron X-, Y-, and Z-slides ensure exceptional rigidity. With a tool magazine capacity of up to 60 tools and a rapid traverse speed of 30 m/min, this machine is built for productivity and reliability.
Country of Origin: Austria
BEYOND STANDARD
The EMCO ECOMILL 1200 is a robust 3-axis machining center engineered for versatility and precision. With a large 1,500 kg table load capacity, high-rigidity cast components, and rapid traverse speeds of up to 30 m/min, it ensures smooth and efficient operation. Powered by Siemens or Heidenhain controls, this machine is built for long-term reliability and performance in demanding milling applications.
SPEED MEETS PRECISION
The EMCO ECOMILL 1200 delivers powerful cutting capabilities with a main spindle speed of up to 12,000 rpm and 73.8 ft-lb (100 Nm) of torque, ensuring smooth performance on tough materials. An optional motor spindle with 15,000 rpm provides even greater speed for high-precision milling. With rapid traverse rates of 1,181 in/min (30 m/min) and acceleration up to 9.8 ft/s² (3 m/s²), the ECOMILL 1200 is engineered for fast cycle times and optimized efficiency in every machining application.
47.2" / 24.0" / 19.7" (1200 mm / 610 mm / 500 mm)
9.8 ft/s² (3 m/s²)
0.0004" (10 µm) / 0.00016" (4 µm)
Why Choose EMCO?
Precision engineered. Performance delivered.
Innovative Machining Solutions
EMCO develops flexible, high-performance machining systems built for industries like aerospace, automotive, and general manufacturing.
Built by EMCO
Every EMCO machine is designed and manufactured in-house, ensuring the highest level of quality, precision, and technological innovation.
Engineered for 24/7 Production
Designed for durability and efficiency, EMCO machines deliver stable performance in demanding, multi-shift environments.
Comprehensive Lifecycle Support
From installation to maintenance and upgrades, EMCO provides full-service support to maximize uptime and productivity.
Global Reach, Local Expertise
With worldwide manufacturing and service hubs, EMCO delivers reliable solutions and expert support wherever you operate.
