SYIL X7 Vertical Mill
Prices Starting at:
- Axis travels of 15.7″ × 11.8″ × 15″ (400mm × 300mm × 380mm)
- 16-unit ATC arm type
- 12,000RPM BT30 spindle
- High-quality Epoxy Granite frame by SCHNEEBERGER (Swiss)
- High-precision ballscrew and linear guide by THK (Japan)
- SIEMENS SINUMERIK 828D 15" touch screen CNC Controller with 3-axis Servo Motors
- NC rotary table servo type
- 4th axis 125mm size kits including servo motors and driver
- Taiwan Made and Gear type (for SIEMENS controller)
- Tail Stock for 125mm NC rotary table
- Face Plate Tailstock for 125mm NC rotary table
- Probe System: Wireless type
- Tool Setter Kits: Cable type TTC200
- Filtermist
- Chip Conveyor
SYIL X7
A compact, cost-effective CNC milling machine that excels in heavy-duty projects with its powerful, precise, and robust design. Effortlessly cut through tough materials and deliver superior surface results.
27.6" × 11.8" (700 × 300mm)
3 × 14 × 3.9" (100mm)
330lb (150kg)
70.9" × 63" × 88.6" (1800 × 1600 × 2250mm)
15.7" (400mm)
11.8" (300mm)
15" (380mm)
5.9"-20.9" (150-530mm)
14.1" (358mm)
BT30
12,000 RPM
Belt
393.7 ipm (10 m/min)
1,181.1 ipm (30 m/min)
SCHNEEBERGER
Mineral cast machine frame
THK
4th Axis
Add a 4th axis to your 3-axis machining center
High-speed Servo Tool Changer
12 positions BT30
Robert S.
Why Choose the X7 Small CNC Machine?
There are several advantages to using an X7 Small CNC machine for your machining needs.
The SYIL X7 offers powerful performance in a compact design, perfect for small shops. Its mineral cast bed provides unmatched rigidity and thermal stability for precise machining. The water-cooled spindle ensures smooth, consistent operation even under demanding workloads. This compact powerhouse is built to handle tough jobs with ease. Experience reliability and stability in every cut.
Designed with machinists in mind, the SYIL X7, offering a fully enclosed workspace and stainless steel panels for added protection. Its chip evacuation system keeps the work area clean, while an ergonomic layout simplifies loading and unloading. Maintenance is straightforward with easy access to all components. The system is automation-ready, giving you room to grow as your needs evolve. Built for convenience, it’s a perfect fit for any modern shop.
The small SYIL X7 CNC machine offers a small footprint with unprecedented speed. It provides full CNC capabilities in a compact space, ensuring high processing quality. Moreover, this efficiently competent CNC mill comes at an affordable price. Due to its excellent competency and high affordability rates, it is the right match for all CNC cuttings at low unit costs.
Compact and precise, the SYIL X7 is ideal for prototyping and small-batch production. Set it up in tight spaces without sacrificing performance. Quickly create prototypes or small runs with accuracy, saving time and reducing waste. Whether you’re testing designs or fulfilling custom orders, it’s built to keep up with your shop’s needs. This machine lets you work faster and smarter, keeping costs low and quality high.
The SYIL X7 combines high power and spindle speed to handle tough materials like aluminum, steel, and brass. Its precision ensures every part meets exact specifications. With tight tolerances and advanced control systems, it guarantees consistent results every time. This machine is versatile enough for intricate designs and durable enough for larger projects. Boost productivity, save on labor, and deliver superior quality.
A CNC machine tool built to transform small manufacturing. The SYIL X7's compact size fits tight spaces but offers a spacious work envelope. With higher rapids and a high-speed spindle, it reduces non-cutting time and maximizes efficiency. The vertical milling design simplifies setup and ensures consistent quality. It’s the ultimate machine for small shops looking to save time and cut costs.
Additional Features
ATC Type
16 Positions
2.5" (63mm)
7.9" (200mm)
6.6lb (3kg)
1.5s
7.5/11 kW
1.1/2.2/2.2 kW
AC380V/3-Phase
14 kVA
4,850lb (2200kg)
