STATION 07: FORWARD PORT in TITANIUM CNC MACHINED on a DN SOLUTIONS MYNX 7500/50H with KENNAMETAL TOOLING
Part | Forward Port |
Industry | Aerospace |
Machine | DN Solutions MYNX 7500/50H |
Tooling | Kennametal Tooling |
Material | 6AL-4V Titanium |
Featured in this Project
DN Solutions MYNX 7500/50II
Empower your production with the DN Solutions MYNX 7500/50II Vertical Machining Center, designed for heavy-duty cutting with high precision across diverse applications. This robust unit features a 6000 RPM spindle, BIG PLUS CAT 50 taper, and extensive X-axis travel up to 1525 mm, ensuring both strength and precision in your machining processes.
Schunk KSG 125 NC Clamping Vise
The Schunk KSG 125 NC Clamping Vise is engineered for high-precision and efficient clamping in CNC machining operations. This compact and powerful vise offers exceptional rigidity and repeatability, making it an ideal choice for intricate and demanding machining tasks that require absolute stability and accuracy.
Hardware, software, tooling, coolant, workholding, and more used in the demonstration of this project during the BOOMBASTIC OPEN HOUSE EVENT.
DN Solutions MYNX 7500/50II with Fanuc Control
Blaser Swisslube SYNERGY 735
Tool # | Tool Description | Model Number |
1 | Kennametal HARVI III 3/4” Solid Carbide Endmill (ROUGHING) SFM: 400 | IPM: 52 |
MM# 7077039 |
2 | Kennametal Indexable 1 1/4" Drill SFM: 260 | IPM: 2.2 |
MM# 4122636 |
3 | Kennametal HARVI I TE 1/2" Solid Carbide Endmill (ROUGHING) SFM: 400 | IPM: 50 |
4 | Kennametal HARVI I TE 3/8" Solid Carbide Endmill (ROUGHING) SFM: 500 | IPM: 20 |
5 | Kennametal GOdrill .2559" 5xD Solid Carbide Drill SFM: 109 | IPM: 3.9 |
6 | Kennametal GOdrill .4134" 5xD Solid Carbide Drill SFM: 109 | IPM: 3.4 |
MM# 4150985 |
7 | Kennametal HARVI I TE 1/4" Solid Carbide Endmill SFM: 200 | IPM: 24 |
8 | Kennametal HARVI III 3/4" Solid Carbide Endmill (FINISHING) SFM: 500 | IPM: 20 |
MM# 7077039 |
9 | Kennametal HARVI I TE 1/2" Solid Carbide Endmill (FINISHING) SFM: 400 | IPM: 30 |
10 | Kennametal HARVI I TE 3/8" Solid Carbide Endmill (FINISHING) SFM: 500 | IPM: 20 |
11 | Kennametal HARVI I TE 1/8" Solid Carbide Endmill (ROUGHING) SFM: 180 | IPM: 8.8 |
12 | Kennametal HARVI I TE 1/8" Solid Carbide Endmill (FINISHING) SFM: 250 | IPM: 10 |
13 | Kennametal DUO-LOCK 3/8" Chamfer Mill SFM: 295 | IPM: 10 |
MM# 6127351 |
14 | Multi-Form 5/16-18" Threadmill SFM: 175 | IPM: 6 |
15 | Custom 1/2" Undercut Endmill SFM: 225 | IPM: 7 |
16 | Kennametal Inserted .670" Threadmill SFM: 175 | IPM: 6 |
MM# 3030845 |
17 | Kennametal DUO-LOCK 1/2" Ball Endmill SFM: 225 | IPM: 25 |
MM# 6070992 |
Aerospace Academy
Propelling machinists and companies to the next stratosphere of CNC Machining.
