Portable Surface Roughness Testers
#SJ411
Product Details
- Equipped with 46 roughness parameters that conform to the latest ISO, DIN, ANSI, and JIS standards
- A wide-range, high-resolution detector and a drive unit provide superior high accuracy measurement in its class
- Ultra-fine steps, straightness and waviness can be measured by using the skidless measurement function
- The handheld data processing unit and the 5.7-inch color graphic LCD touch-panel provides superior readability and operability. The LCD also includes a backlight for improved visibility in dark environments
- The excellent user interface provides intuitive and easy-to-understand operability
- Measured data can be output to a PC with optional RS-232C or USB cable.
- Digital filter function for non-distorted roughness profiles.
- GO/NG judgment function
- Auto-calibration function
- 16 languages, which can be freely switched
- Supports the four types of measurement: step, level change, area and coordinate difference
- Access to each feature can be password protected, which prevents unintended operations and allows you to protect your settings
- Optional attachments for mounting on a column stand significantly increase the operability
- Skidded and Skidless
- Drive Unit: Standard
- Detector: 4mN
- Display Unit: Compact
- Stylus Tip Radius: 5µm
- Evaluation Range: 1 In/25mm
- Measuring range: 800μm
- Drive unit
- Straightness/traverse length
- SJ-411: 0.3μm/25mm
#SJ210
Product Details
- 2.4-inch color graphic LCD with backlight
- Up to 10 measurement conditions and one measured profile can be stored in the internal memory
- Optional memory card can be used as an extended memory to store large quantities of measured profiles and conditions
- Access to each feature can be password-protected, which prevents unintended operations and allows you to protect your settings
- Display interface supports 16 languages, which can be freely switched
- Alarm warns you when the cumulative measurement distance exceeds a preset limit
- Complies with the following standards: JIS (JIS-B0601-2001, JIS-B0601-1994, JIS B0601-1982), VDA, ISO- 1997, and ANSI
- Displays both total and sectional measurement results as well as evaluation curve, BAC, ADC and waveform
- Built-in battery allows approximately 1,000 measurements on a full charge
- Detector: 4mN
- Measuring Force: 4mN
- Evaluation Range: .7 In/17.5mm
- Skidded
Sale price$2,700.00
Regular price$2,790.00 (/)
