Machine tool in production. Ships later this year.
SYIL X9 Vertical Mill
Prices Starting at:
First-Class Components and Solid Construction.
Standard Package
- Axis travels of 29.9" × 19.7" × 19.7" (760 × 500 × 500mm)
- 24-pocket high-speed servo tool changer
- 10,000 rpm BT40 spindle
- SCHNEEBERGER mineral casting
Customization Options
- 24,000 rpm HSK-A63 Build-in Type with Power Drawbar System
- NC rotary table servo type | 4th axis 255mm size kits including servo motors and driver
- Tail Stock for 255mm NC rotary table
- Probe System | Wireless type
- Tool Setter Kits | Cable type TTC200
- Filtermist
- Central Coolant System (CTS 20 Bar)
- Chip Conveyor
SYIL X9
Excellent Machining Capabilities. Handling a Full Range of Operations.
33.9" × 19.7" (860 × 500mm)
18" × 5" × 3.9" (100mm)
1,102lb (500kg)
72.8" × 88.4" × 110.2" (1850 × 2245 × 2800mm)
29.9" (760mm)
19.7" (500mm)
19.7" (500mm)
3.9"-23.6" (100-600mm)
20.9" (530mm)
BT40
10,000 rpm
Belt Type / Direct Type
393.7 ipm (10 m/min)
1,181.1 ipm (30 m/min)
SCHNEEBERGER
Mineral cast machine frame
THK
4th Axis
Add a 4th axis to your 3-axis machining center
Robert S.
Additional Features
Arm Type
24 Positions
4.9" (125mm)
9.4" (240mm)
15.4lb (7kg)
2s
11/17 kW
3.9/3.9/5.9 kW
13,228lb (6000kg)
