SUPPORT FREE EDUCATION
SKU: 34608787
MACHINIST'S STONE | 100mm X 40mm | Grit C120/C320V
Sale price$94.95 Regular price$99.95
TYROLIT X TITANS of CNC means unparalleled quality!
Product Details
  • The Tyrolit Machinist's Stone is precision ground to an optimal flatness profile.
  • Built with a two-layer construction process: One layer contains a relatively rough silicon carbide grit with 120 mesh grit dimension to guarantee a certain material removal and the opposite layer contains a fine silicon carbide grit with 320 mesh grit size to ensure a smooth surface finish.
  • Both layers are made with a medium-hard vitrified bond system to achieve a free cutting behavior and at the same time keep the plane surface the machinist desires for a long time.
  • Apply the stone to the surface with coolant or lubricant to achieve the best result.
Property Value
Unit of Tool Metric
Form 90KR
Grit 120/320
Dimensions 100mm x 40mm
Care Instructions
  • Store the stone on safe, flat surface to maintain its edge.
  • Before first use soak the stone with coolant (water or emulsion).
  • To remove rust, dust, and chips work with the coarse part of the stone (C120)
  • To achieve a perfect surface finish use the fine part at the end.
  • Clean the stone with high-pressure water spray or air after every use.
  • IMPORTANT: Use the entire surface when stoning your work envelope. Avoid only using the edges.
Country of Origin: Austria
Stocked: United States of America.
