Machine tool in production. Ships later this year.
SYIL X11 Vertical Machining Center
Prices Starting at:
Designed for Large Workpieces
Features
- Axis travels of 39.37" x 19.69" x 19.69" (1000 x 500 x 500 mm)
- 24-pocket high-speed servo auto tool changer
- 12,000 rpm BT40 spindle
- SCHNEEBERGER mineral casting
Customization Options
- NC rotary table servo type | 4th axis 255 mm
- Tail Stock for 255 mm NC rotary table
- Probe System | Wireless type
- Tool Setter Kits | Cable type TTC200
- Filtermist
- Central Coolant System(CTS 20 Bar)
- Chip Conveyor
SYIL X11
This affordable and versatile vertical machining center is perfect for medium and large workpieces. Excelling in both ferrous and non-ferrous materials, the SYIL X11 delivers high-quality results while efficiently surpassing industry standards.
41.34" x 21.65" (1050 x 550mm)
0.71" x 0.20" x 3.54" (18 x 5 x 90mm)
1322.77 lbs (600kg)
106.30" x 90.55" x 110.24" (2700 × 2300 × 2800mm)
39.37" (1000mm)
19.69" (500mm)
19.69" (500mm)
4.33"-24.01" (110 - 610mm)
25.59" (650mm)
BT40
12,000 rpm / 10,000 rpm
Direct/Belt
393.70"/min (10,000mm/min)
1181.10"/min (30,000mm/min)
SCHNEEBERGER
High-precision mineral casting bed
THK
4th Axis
Optional 4th-Axis
High-Speed Servo Tool Changer
24 position, BT40
Robert S.
Why Choose the X11 Vertical Machining Center?
There are several advantages to using an X11 Vertical Machining Center for your machining needs.
Excellent Features
- Strong and reliable performance
- Compact machine layout
- Mineral cast bed
- High rigidity and good thermal stability
- Electric spindle with water cooling function
Sleek Design
- Fully enclosed working area with stainless steel guard plate
- Designed for easy chip removal
- Ergonomic operation and workpiece loading/unloading
- Easy access to equipment units for maintenance
- Expandable and customizable automation system
Versatile and Cost-Effective
The cost-effective X11 offers a compact design, making it ideal for companies looking to optimize their space.
Its user-friendly interface and software ensure easy operation, while its high-quality construction guarantees durability.
Whether you're machining a variety of materials, or want an affordable solution for your production line, the SYIL X11 is a smart investment that checks both boxes.
Additional Features
Arm Type
24 Positions
4.72" (120mm)
11.81" (300mm)
15.43 lbs (7kg)
2.5s
14.75/22.80 hp (11/17kW)
5.23/5.23/7.92 hp (3.9/3.9/5.9kW)
AC380V/ 3-Phase
15432.36 lbs (7000kg)
