Machine tool in production. Ships later this year.
SYIL T5 Drill Tap Mill
Prices Starting at:
Enhanced Efficiency and Accuracy
Features
- Axis Travels of 23.62" x 17.72" x 12.99" (600 x 450 x 330 mm)
- 21-pocket High-Speed Servo Tool Changer
- 20,000 rpm Direct BT30 Spindle
- High-Precision Mineral Casting
- THK Ball Screw and Linear Guide
Customization Options
- NC rotary table DDR type | 4th axis 170mm size kits including servo motors and driver | Taiwan Made and DDR type
- NC rotary table Gear type | 4th axis 170mm size kits including servo motors and driver | Taiwan Made and Gear type
- Tailstocks for gear type 4 axis
- Probe System | Wireless type
- Tool Setter Kits | Cable type TTC200
- Filtermist
SYIL T5
The SYIL T5 drilling/tapping machine automates your process, and has the effect of increasing your efficiency and productivity while reducing labor costs.
27.56" x 16.54" (700 x 420mm)
3 x 0.56" x 4.92" (3 x 14.3 x 125mm)
551.16 lbs (250kg)
82.60" x 61.02" x 81.50" (2098 x 1550 x 2068mm)
23.62" (600mm)
17.72" (450mm)
12.99" (330mm)
5.91"-18.90" (150-480mm)
12.60" (320mm)
BT30
20,000 rpm
Direct
787.40"/min (20,000mm/min)
1,889.76"/min (48,000mm/min)
Expoxy Granite Frame
Precision mineral bed
THK
4th-Axis
Optional 4th-Axis
21 positions BT30
Robert S.
Why Choose the T5 Drill Tap Mill?
Using a drilling and tapping machine offers several advantages in industrial manufacturing. Firstly, it significantly increases efficiency and productivity by automating the process of drilling holes and creating threads. This allows for faster production times and higher output rates, saving valuable time for manufacturers.
Additionally, drilling and tapping machines reduce the labor costs typically associated with manual drilling and tapping processes.
By eliminating the need for constant supervision or physical exertion from workers, companies can allocate their resources more effectively.
Powerful Features
- Powerful and reliable performance
- Compact machine layout, suitable for production line integration
- Mineral-cast bed structure
- High rigidity and good thermal stability
- Direct drive servo motor, high precision guideways
Sleek Design
- Fully enclosed work area with stainless steel protection plates
- Easy chip disposal design
- Ergonomic operation and loading/Unloading design concept
- Easy access to equipment units for easy maintenance
- Expandable and customizable automation system
Automation
Significantly increases efficiency and productivity by automating the process of drilling holes and creating threads. This allows for faster production times and higher output rates, saving valuable time for manufacturers. Additionally, with the ability to accurately drill and tap with precision, this machine ensures consistent results every time.
Save Time and Money
Reduce labor costs associated with manual drilling and tapping processes! By eliminating the need for constant supervision or physical exertion from workers, companies can allocate their resources more effectively. Moreover, using a CNC drill tap machine like the SYIL T5 provides versatility across various applications in industries such as automotive parts manufacturing or aerospace engineering—making it an ideal choice for corporations looking to streamline their operations without compromising quality.
High-Quality and Reliable
When you buy a CNC drilling and tapping machine from SYIL Machine Tools, you can trust that you are getting a high-quality and reliable product. Our machines are built with precision engineering and designed to withstand the demands of industrial manufacturing. You can count on consistent performance and accuracy, ensuring efficient production processes.
Customizable
SYIL Machine Tools offers customizable options for our CNC drilling and tapping machines. We understand that every manufacturer has unique needs, so we provide flexible solutions to meet your specific requirements. From different spindle configurations to advanced control systems, you can customize your machine to optimize productivity and achieve the desired results.
Additional Features
Wheel Type
21 Positions
2.48" (63mm)
9.84" (250mm)
6.61 lbs (3kg)
1s
4.96/7.38 hp (3.7/5.5kW)
2.01 hp (1.5kW)
AC380V/ 3-Phase
4740 lbs (2150kg)
4960 lbs (2250kg)
