Due to overwhelming demand for this product, the manufacturer is experiencing unexpected shipping delays beyond our control.
IP65 QuantuMike Digimatic Outside Micrometer
#34in7621016mm-NoOutput
Product Detail Specifics to the 3-4" No Output Variant
- Faster measurement with 2mm per rev. instead of the standard 0.5
- A patented ratchet thimble mechanism helps ensure repeatability
- A function lock helps prevent error
- Certificate of inspection is provided
- With standard bar, except 0-25mm/0-1" model
- Supplied in fitted plastic case
- Dust/Water protection level: IP65
- Accuracy: Refer to the list of specifications
- Resolution: 0.001mm or .00005"/0.001mm
- Flatness: 0.3µm/.000012"
- Parallelism: 1µm/.00004" for models up to 50mm/2", 2µm/.00008" for models up to 100mm/4"
- Measuring faces: Carbide tipped
- Display: LCD
- Battery: SR44 (1 pc.), 938882
- Battery life: Approx. 1.2 years under normal use
#34in7621016mm-SPCDataOutput
Product Detail Specifics to the 3-4" SPC Data Output Variant
- Display: LCD
#23in508762mm-NoOutput
Product Detail Specifics to the 2-3" No Output Variant
- A function lock helps prevent error IP-65 protection level
- Display: LCD
#23in508762mm-SPCDataOutput
Product Detail Specifics to the 2-3" SPC Data Output Variant
- Display: LCD
#12in254508mm-NoOutput
Product Detail Specifics to the 1-2" No Output Variant
- Display: LCD
#12in254508mm-SPCDataOutput
Product Detail Specifics to the 1-2" SPC Data Output Variant
- Display: LCD
#01in0254mm-NoOutput
Product Detail Specifics to the 0-1" No Output Variant
- Display: LCD
#01in0254mm-SPCDataOutput
Product Detail Specifics to the 0-1" SPC Data Output Variant
- Display: LCD
Save BIG when you BUNDLE.
Boost your shop's accuracy and quality with our tooling kits. When your reputation is on the line, you need reliable inspection gear to deliver excellence every project.
