Due to overwhelming demand for this product, the manufacturer is experiencing unexpected shipping delays beyond our control.
Digimatic Depth Micrometer (w/interchangeable rods)
Product Details
- Ø4mm interchangeable rods, with lapped measuring end, provide a wide measuring range
- The rod length can be adjusted in 25mm or 1in increments
- With ratchet stop for constant force
- With measuring rod clamp
- With SPC output
- With digit counter
- Supplied in fitted plastic case
#06in-01524mm
- Accuracy: ±.00015in ±3µm for micrometer head feed ±[.00008 + (.00004xR/3)]in R= max. measuring length (inch) ±(2+L/75)µm for interchangeable rod, L=Max. measuring length (mm)
- Resolution*: 0.001mm or .00005"/0.001mm
- Graduation**: 0.01mm or .001in
- Flatness of reference face: .00005in for 2.5in/1.3µmfor 63.5mm width base, .00008in for 4in/2µm for 101.6mm width base
- Flatness of measuring rod face: 0.3µm
- Parallelism between reference face and measuring rod face: [.00016 + (.00004 x R/2]in R=max. measuring range (inch)
- (4+L/50)µm, L=Max. measuring length (mm) Measuring rod diameter: .157in/4mm
- Display: LCD
#012in-03048mm
- Display: LCD
Save BIG when you BUNDLE.
Boost your shop's accuracy and quality with our tooling kits. When your reputation is on the line, you need reliable inspection gear to deliver excellence every project.
