Double Door Opener
Priced from
$10,128 - $15,028
This model consists of two door openers, the left and the right version, with two controllers in one electrical cabinet. The controllers open the machine doors simultaneously. Both machine doors can have different opening length from each other.
- Plug & play servo-controlled door opener
- Successfully installed on thousands of existing and new CNC machines
- 100% safe and CE-certified
- Includes: Controller with auto-learn mode for installation, universal mounting brackets, I/O cables, and a clear instruction manual
- Available in door travel lengths from 700mm - 3,000mm
- Can support door weights from 180kg up to 400kg
- Packaged and shipped within the United States
Country of origin: Netherlands
Automation
The CNC AutoDoor control box needs just two signals to operate the machine door, making it a universal plug & play system compatible with any CNC machine and all robot and cobot brands.
100% Safe
The servo-controlled door openers come with a self-learning control box featuring a Siemens module, automatically detecting resistance, ensuring 100% safety for the CNC AutoDoor without the need for extra limit switches, light curtains, or pressure switches.
Universal Mount
Each system includes universal mounting brackets for easy installation on any CNC machine and can be controlled either by the CNC machine's I/O signals or optional push buttons.
Automation. Simplified.
Why Choose the CNC AutoDoor?
Efficient and Safe
CNC AutoDoor is designed to automatically open and close CNC machine doors. It has a servo-controlled opener with a smart control box, featuring a Siemens module that learns on its own and senses resistance, making it 100% safe!
Fits Any CNC Machine Tool
The CNC AutoDoor comes with universal mounting brackets, making it a snap to install on any CNC machine. You can control the door opener with the CNC machine's I/O signals or some extra push buttons. Plus, it's available in various lengths, from 700mm to 3,000mm.
Quality and Reliability
CNC AutoDoor is all about top-notch quality, using only the best components. Each system is carefully assembled and tested before it ships to you.
