Due to overwhelming demand for this product, the manufacturer is experiencing unexpected shipping delays beyond our control.
Absolute Digimatic Bore Gage
Product Details
- Interchangeable anvil is attached to a micrometer head for accurate dimensional setting
- Wide measuring range with sub-anvils
- Carbide ball contact point for durability
- Extension rods (optional) can be attached for measuring deep holes
- Optional Setting Rings offer the best method of zero-setting Bore Gages
- Dust/Water protection level: Conforming to IP53
- Accuracy: Wide Range: 0.003mm/.00012"
- Narrow Range: 0.002mm/.00008" Resolution: .00005"/0.001mm
- Display: LCD
- Battery: SR44 (1 pc.)(938882)
- Battery life: Approx. 9 months for normal use
Functions
- Origin-set, Zero-Setting, Presetting, Power on/off, inch/mm conversion (inch/mm type only),
- Data output, GO/±NG tolerance judgment
- Alarm: Low battery voltage, scale contamination, over-flow error, tolerance limit setting error
Save BIG when you BUNDLE.
Boost your shop's accuracy and quality with our tooling kits. When your reputation is on the line, you need reliable inspection gear to deliver excellence every project.
