Keeps your worktable clean of burrs and other debris. FREE SHIPPING in the Continental USA.
MACHINIST'S STONE | 100mm X 40mm | Grit C120/C320V
TYROLIT X TITANS of CNC means unparalleled quality!
- The Tyrolit Machinist's Stone is precision ground to an optimal flatness profile.
- Built with a two-layer construction process: One layer contains a relatively rough silicon carbide grit with 120 mesh grit dimension to guarantee a certain material removal and the opposite layer contains a fine silicon carbide grit with 320 mesh grit size to ensure a smooth surface finish.
- Both layers are made with a medium-hard vitrified bond system to achieve a free cutting behavior and at the same time keep the plane surface the machinist desires for a long time.
- Apply the stone to the surface with coolant or lubricant to achieve the best result.
Country of Origin: Austria
Stocked: United States of America.
Property | Value |
Unit of Tool | Metric |
Form | 90KR |
Grit | 120/320 |
Dimensions | 100mm x 40mm |
Care Instructions
- Store the stone on safe, flat surface to maintain its edge.
- Before first use soak the stone with coolant (water or emulsion).
- To remove rust, dust, and chips work with the coarse part of the stone (C120)
- To achieve a perfect surface finish use the fine part at the end.
- Clean the stone with high-pressure water spray or air after every use.
- IMPORTANT: Use the entire surface when stoning your work envelope. Avoid only using the edges.
Say YES! to Success!
When Barry Setzer, our resident CNC EXPERT, says this machinist's stone is "the best on the market", he means it. The TITANS of CNC X TYROLIT STONES are made from the highest quality materials and ready to ship worldwide!
